phone  (937) 890-5197
Shopsmith Forums
%nbsp;
12 posts 1 2
Rockler work bench casters
#102765 by wannabewoodworker » Fri Nov 18, 2011 1:52 am
So I was reading the caster thread and it reminded me about the Rockler catalog I received the other day. I was pleased to see a new item and it was a set of retractable casters for work benches. I may buy a set of these for my expending work table i built a while back ago. I have some home made retractable casters i made but they have proven to be not so durable and i have had to fix the mounting several times. These new Rockler casters would alleviate my work bench issue. I was thinking that these might be retrofit to the SS but after looking more closely at them it would take some considerable modification to the SS to make these work and I don't want to go there. They should work great for my work bench though. Not crazy about the price but they seem to be the best thing out there at the moment.
http://www.rockler.com/product.cfm?page=30842&filter=New%20Products
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc.
albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....:D
#102787 by damagi » Fri Nov 18, 2011 10:04 am
I got a set for my bench and so far so good. I have a Sjorberg Elite Duo that I picked up super cheap, so thats about 90 lbs unloaded. The casters are rated for 100lbs each, so 400 lbs total, which should be fine once I add a cabinet underneath it plus some tools. The parts are nice quality overall, and the casters are very nice. Having priced casters recently, these ones look to be about 20-30 worth of casters alone if you were to buy them on your own.
One thing to note on my specific bench was that the vertical portion of the legs is inset by about 1/8" from the horizontal foot. Based on where the mounting holes need to go, I ended up needing to put a small shim behind the plate for the top hole. The kit comes with screws that seem to work fine, though it might be worth it to switch to bolts/nuts depending on your scenario. Also, it was easier for me to disassemble the bracket to screw it in without interference. And the instructions are simply a picture showing the height for the holes from the ground.
So far so good. It accomplishes my main issue with other caster systems in that when the wheels are disengaged they are totally out of the equation. I saw some suggestions of locking casters, but for a workbench that you don't want to move when you are pushing against it that just doesn't fly.
Note that, depending on the design and location of your bench, the feet flippers may stick out in an akward way. You might consider mounting them inside the legs rather than outside to avoid that issue.
damagi AT gmail DOT com
#102798 by robinson46176 » Fri Nov 18, 2011 1:45 pm
A little ouchy on the price but very nice looking casters.
I will probably stick to the hinged board with casters approach. Either that or a pair of rigid wheels mounted on the end with the most overhang and a pair of wheel barrow type handles to pull out of the other end to lift it placing the weight on the wheels.
I have a couple of skate-boards that I use for moving some heavy stuff on. They work very well and can be bought at yard sales for a dollar or two.
I really should design and build a new bench but I cobbled this one together many years ago and it is kind of an old friend. :) OK, not a particularly pretty old friend...
#102801 by damagi » Fri Nov 18, 2011 2:15 pm
Also note - I am a little surprised there aren't pre-drilled holes to mount a board across the casters. In thinking about it, I think I will likely mount a board across them so that I can activate both sides at the same time to prevent twisting forces.
#102819 by fjimp » Fri Nov 18, 2011 6:22 pm
I have decided to go a different route for castors. Woodcraft has these 300 pound capacity locking castors on sale.
http://www.woodcraft.com/Product/2001989/22733/3-Caster-Double-Locking-Swiveling-with-12-Threaded-Spindle.aspx
I have about 30" of 1 1/2" wide X 1/4" thick angle iron on hand. I will cut eight pieces of 3" long angle iron and use two pieces for each castor. One piece will protrude from end of bench and contain a hole for the castor to bolt thru. The other piece will be behind and under the leg adjacent to the iron on the front side. The back, bench leg and front iron piece will all be bolted together and with the castors on sale for $12.95 each I will spend under $50 and have 300 pound per castor weight bearing capacity. I expect that will work well for me. Then like Farmer I will be the only thing in the shop not on wheels. Well okay sometimes I use my tractor seat and am on wheels in the shop. Fjimp
F. Jim Parks
Lakewood, Colorado:)
#102821 by damagi » Fri Nov 18, 2011 6:37 pm
fjimp wrote:I have decided to go a different route for castors. Woodcraft has these 300 pound capacity locking castors on sale.
I hope these work out for you. My local woodcract had these on an identical bench to mine and it seemed to wiggle a bit when pushed, even when locked. They may have only used single locking rather than double locking. Either way, I look forward to seeing/hearing how it works.
#102822 by JPG » Fri Nov 18, 2011 6:50 pm
If I were going to use two angle iron for each castor, I would position them like a "T" with the common side horizontal(with the caster mounting hole) and the vertical sides extending both above and below the horizontal sides. That allows twice as many mounting bolts spread over a larger area. Washers(or a plate) could be used on the back side of the leg.
Fodder for de noggin!;)
Goldie(Bought New SN 377425)/4" jointer/6" beltsander/12" planer/stripsander/bandsaw/powerstation /Scroll saw/Jig saw /Craftsman 10" ras/Craftsman 6" thicknessplaner/ Dayton10"tablesaw(restoredfromneighborstrashpile)/ Mark VII restoration in 'progress'/ 10E(SN E3779) restoration in progress, a 510 on the back burner and a growing pile of items to be eventually returned to useful life. - aka Red Grange
#103379 by karensara » Mon Nov 28, 2011 4:11 am
I have castors on almost all of my things and have purchased huge ones with the best quality off of ebay personally. They are durable, can hold great deals of weight and are better than any I have purchased in the local stores which cannot hold up at all, not to mention they were much more reasonably priced.
#132508 by jhony » Mon Dec 10, 2012 12:36 am
hahahahaaaaaaaa----
testking study guide testking study guide
#132631 by letterk » Mon Dec 10, 2012 8:18 pm
I have a set of theses casters and they work great. I also have a 55" Sjobergs 1600 model bench and fully loaded it lefts and moves the bench with no problems. They must be popular because when I bought them they were $75 plus I used a 20% off coupon. Now I think they are $80.
Just picked up a second set as a customer return of really cheap, now I have to figure out where I going to use them.
Who is online
Users browsing this forum: algale, Gene Howe, jsburger and 17 guests
Welcome to Shopsmith. Please fill in this form and we'll send you more information about the Shopsmith MARK 7 and other woodworking topics.
First Name: Last Name:
Address:
Optional Extra Address Line:
City: ST: Zip:
Email:
Re-Enter Email Address:
Phone: ( ) -
NO - I do not yet own a MARK 7 or Mark V
YES - I own a MARK 7 or Mark V
Submit
