plantation shutter
tangel
plantation shutter
Post by tangel »
I,m new at this I would like to make some plantation shutters so I need all kind of help how to make them and where to get parts. Thanks for any help
Plantation Shutter
I have no experience making plantation shutters - but I know who does:
http://www.shopsmith.net/forums/showthread.htm?t=801
Check out thread #8. While you're there - check out the beutiful work this guy does.
tangel wrote:I,m new at this I would like to make some plantation shutters so I need all kind of help how to make them and where to get parts. Thanks for any help
Tangel - I'm just a beginner with plantation shutters (I've only "almost" completed the first one - maybe 9 or ten to go). I feel for you, in your effort to find information. Here is a list of the INTERNET sites I found most helpful:
http://www.shuttermedic.com/
http://www.martinshutters.com/
http://www.buyplantationshutters.com/shutters/components.html
http://www.woodline.com/v2/p-1775-pin-tensioner-accessory-kit.aspx
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=812-395
http://www.woodsmith.com/files/issues/151/window-shutters.pdf
http://www.profhdwr.com/34500.htm
http://www.woodline.com/v2/c-63-case-moulding.aspx
A big consideration (probably the biggest) is in the planning! Do you want shutters to be mounted on the inside wall, or on a frame that you build? (a frame will probably be the easiest) (I elected to build shutters that will fit inside the window well - this will save space in the room, but is more difficult to fit.) It will require a little more wood to build the frame, but you can easily make your shutters to fit your frame.
Do you want hinged shutters? There is a variety of hinges for shutters.
How are you going to size and shape the louvers? You can have flat louvers, or tapered louvers. If you want tapered louvers, the best way I found is to rout the tapers. Woodline USA has the only bit I've found to do this job. They used to have a Shutter router bit kit. (WL-2055) But I find it is no longer available (made available again this year 1012) on the Net. Maybe if you give them a phone call, they can find one. The Kit came in a wooden box that holds five bits. The most important one they still have (it is sold separately as part No. WL-1433). The other two bits can be found almost anywhere. They are a rabbeting bit (no guide bearing) and a beading bit.
One of these sites at Woodline USA holds a PDF that actually is an instruction article on how to make Plantation Shutters. Whoops - I didn't include it in the list, but here's how to get there: At the Home page of Woodline USA, click on "INSTRUCTIONS" (at the right side of the heavy blue field), then look down the appearing list to click on "Plantation Shutters". This is a valuable PDF. I suggest printing a copy.
Best wishes! If you have any questions - just ask!
P.S. Forgot another! Go to www.newyankeeworkshop.com and look up plans for plantation shutters. Might as well also buy the DVD. It's all about jigs. I didn't follow his plans, but might have saved effort if I had!
I was also somewhat mistaken about the router bit set (WL-2055). It is a 5 piece set containing the molding bit (as mentioned above) and a 3/4"x1" straight bit, a rabbet bit 1 1/2"x3/4" (and it has a pilot bearing), a roundover bit 1 1/8"xR1/4", and the coving bit 3/4"xR1/8". This was a good deal, as it cost only $64.40 delivered and came in a wooden box. The molding bit by itself costs $38.00.
forrestb
Re: plantation shutter
Post by forrestb »
I agree with Chuck. Norm did an excellent job explaining the effort:
http://www.newyankee.com/index.php?id=5 ... /p/7916664
Forrest
I am surprised to see many of the sites I used in 2007 still available. Sorry there isn't more, but times change.
The kit for plantation shutters that was mentioned in 2007 seems it is no longer available, but individual bits are. To help a little, assuming you want to have tapered louvers - that bit is the "Ranch Casing Bit" http://www.woodline.com/p-1302-casebase-molding.aspx .
Maybe you can use the search function to find what's posted here back in 2007 re: Plantation Shutters. I know you've found at least one post. There are several, including photos.
rpd
Post by rpd »
fewlinafeni wrote:I don't no how to make them plantation shutter but i suggest, you can visit this site --- link removed ----
It's a very beautiful site for plantation shutter and I think it workable for you.
I could be wrong, but I am suspicious that this post is spam.
You noticed also!
Not the first 'first time poster' since the forum change.
Hopefully they will be few and far between.
rpd
Post by rpd »
JPG wrote:You noticed also!
I hope so too.
There have been a few since the change but not many.
I have noticed that they have become "stealthier" and only post once, not multiple times as in the past.
Is there a singular tense for "spam"? :rolleyes:
I hope so too.
PAM?
rpd
Post by rpd »
JPG wrote:PAM?
Of course, it must be. How slick is that.
