Belt Sander Troubles
- Bronze Member
I bought a used Belt Sander from the 80s, which had an old power station. I have taken the sander apart and cleaned it twice now and cannot get it to hold the tension on the sanding belt. Aside from sending it in to be repaired, does anyone have any suggestions? Thanks, Dave
Do you have a manual? I've rebuilt a couple, the top roller needs to be turned to apply tension to the built. Spin the knob to the right (I think) until it gets tight. Latch it in place, then slip the belt onto the sander. When you release the lever on the knob, it should unwind, tightening the belt.
Start it up REALLY slow so you can adjust the tracking of the belt with the two horizontal knobs on each side.
Good luck!
Matt
Good luck!
Matt
Lost count, over a dozen rebuilt/repaired/restored
Personal equipment: 510 made in 1993, belt sander, jig saw, band saw, planer and jointer
Matt in GA
Matt in GA
Belt sander tune up in Sawdust Session 12
Check out this video nick did a while back.
http://www.shopsmithacademy.com/SS_Arch ... Tuneup.htm
it should help
it should help
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
thainglo wrote:Do you have a manual? I've rebuilt a couple, the top roller needs to be turned to apply tension to the built. Spin the knob to the right (I think) until it gets tight. Latch it in place, then slip the belt onto the sander. When you release the lever on the knob, it should unwind, tightening the belt.
Good luck!
Matt
Yours has adjustment knobs on BOTH sides?
I think there is only one available from the outside. There is a second adjustment that Nick talks about in the above Sawdust session. but it is internal and set during assembly.
Nope. That is what happens when you're speaking from memory and said memory fails! Thanks for catching.JPG40504 wrote:Yours has adjustment knobs on BOTH sides?
Matt in GA
Matt in GA
I understand that only too well!;)thainglo wrote:Nope. That is what happens when you're speaking from memory and said memory fails! Thanks for catching.
