Shopsmith pro planer with stand feed rollers ???
Tmmoll
Post by Tmmoll »
So I just picked up a pro planer from Craigslist for $45. I went to start it up, and see the feed rollers are pushing the lumber back instead of into the blade. The guys I got it from stated that it was his fathers, and said he had to force the lumber through. I have been woodworking for a long time, however this is my first planer. Is it possible to have these feed rollers motor wired in reverse? I don’t know if it’s been messed with and wired up incorrectly. Does anyone happen to have wiring diagram for this?
Re: Shopsmith pro planer with stand feed rollers ???
I do not believe the feed motor is reversible (even if it was wired wrong).
But let us check a couple things. Assumptions get us in trouble here all the time. You said a Pro Planer therefore there is a crank that raises and lowers the lower table. You should be feeding the planer from that same side.
Now with the cover open you can see the outfeed roller. When running, that roller should be pulling anything laying on the table into the planer. That is to say the feed roller is turning such that the bottom of the roller is moving away from the infeed side.
If the rollers are turning the other way, I do not believe you could feed wood into the planer even with force.
As for a wiring diagram, I have never seen one.
Do not apply a great deal of pressure on the work piece. Adjust the table upward just enough to make the work piece contact the feed roller.
Just had a thought. There are teeth that might possibly be installed backward.
With the planer UNPLUGGED, lay the back of your hand on the infeed table and with your fingers locate these teeth. You should be able to push them away from you but not pull them back toward you. Probably not the issue but too easy to check to disregard.
Are the rollers serrated rubber or are they steel. The roller teeth should be reasonably clear of saw dust.
Tmmoll
Post by Tmmoll »
They are feeding back towards where I am supposed to feed the lumber in. If I feed the wood from the wrong side (blade not running) it feeds perfectly. I have the rubber rollers. It’s like the motor is running in reverse.
Tmmoll
Post by Tmmoll »
So I took the wiring apart at the main control box, found some corrosion so I cleaned it up, hit the roller motor with a hammer a couple of times, and now it’s rolling the right way. Hmmmm.
I ran a 2x4 through it and have chatter marks. I assume just need a good tune up and some sharp blades.
[quote="Tmmoll"]So I took the wiring apart at the main control box, found some corrosion so I cleaned it up, hit the roller motor with a hammer a couple of times, and now it’s rolling the right way. Hmmmm.
I ran a 2x4 through it and have chatter marks. I assume just need a good tune up and some sharp blades.[/quote
First, that is good. The next one is a total "what?". The last one is a quadruple Hmmmm.
Hmmmm indeed!
Yes a DC motor will run in reverse with reversed polarity.
However the speed control is NOT a pure DC source.
It is rather a pulsed source(hence the speed control function) that is derived from ac and uses a triac as the controlling device.
I am curious WHAT was corroded and cleaned up.
It may be possible that that corrosion caused a polarity reversal.
I surmise re the need to push stuff through that that polarity reversal was 'weak'.
As for the scallopimg('chattering') too fast feed rate will create that as well as unequal height of the knives.
