phone  (937) 890-5197
Shopsmith Forums
%nbsp;
13 posts 1 2
Belt Sander Drive Sleeve Replacement
#20594 by jk347 » Fri Aug 15, 2008 1:37 pm
I just ordered a new rubber drive drum sleeve for my SS belt sander. I would appreciate tips and advice on selecting and applying adhesive to the drum and any other comments on the replacement process.
#20599 by beeg » Fri Aug 15, 2008 6:01 pm
Look at this Sawdust session, should answer whatever you need to do.
http://www.shopsmithacademy.com/SS_Archives/SS112/SS112_Index.htm
#20600 by jk347 » Fri Aug 15, 2008 6:30 pm
I watched the video session and it doesn't cover replacing the drive sleeve.
#20604 by beeg » Fri Aug 15, 2008 7:32 pm
Did you order 502789? That's the complete assembly.
Belt Sander Drive Sleeve Cover Replacement
#20608 by billmayo » Fri Aug 15, 2008 9:11 pm
You need to do every thing that Nick does in his Belt Sander session. There is no bolted brackets or holding screws for the bearings. They just fit into each side. You just hold the side bracket and tap the drive sleeve shaft to remove the drive sleeve with the bearings. Be sure you keep and reuse the spring spacers on the outside of the drive sleeve bearings.
I got instructions from Shopsmith with the new drive sleeve cover. You install the cover on the drum. I used some disk soap to slip it on. Then peal one half of the cover over the the other side of the belt cover. I cleaned the 1/2 uncovered drum and 1/2 cover to remove the soap. Then I applied the glue to the drum and rolled the cover back over that side and let if dry. Then I did the opposite side the same way. This is the same way you do the black tires on the bandsaw wheels.
jk347 wrote:I watched the video session and it doesn't cover replacing the drive sleeve.
Bill Mayo [url]bill.mayo@verizon.net[/url]
#20611 by jk347 » Fri Aug 15, 2008 9:52 pm
Thanks billmayo - what type of adhesive did you use?
#20613 by jk347 » Fri Aug 15, 2008 9:58 pm
beeg - I didn't order the entire assembly - just the rubber sleeve.
#20618 by billmayo » Sat Aug 16, 2008 1:26 am
If I remember correctly, the Shopsmith Customer Service lady recommended adding a bottle of adhesive to my belt sander drive sleeve. It was the same bottle that is in the bandsaw black tire package (555644). I find the Shopsmith CS people are excellant in finding parts/items that are not listed in their catalog.
jk347 wrote:Thanks billmayo - what type of adhesive did you use?
#20629 by beeg » Sat Aug 16, 2008 1:28 pm
And that is Dap Weldwood contact adhesive I believe.
The parts list for the belt sander shows that sleeve as part of an assembly, looked like it wasn't available separately. There wasn't a part number for it. Learn something new at least weekly. :)
#20635 by charlese » Sat Aug 16, 2008 2:20 pm
beeg wrote:[color="Blue"]And that is Dap Weldwood contact adhesive I believe. [/color]
That is Affirmative!! Just checked on my bandsaw tire kit!
Who is online
Users browsing this forum: No registered users and 8 guests
Welcome to Shopsmith. Please fill in this form and we'll send you more information about the Shopsmith MARK 7 and other woodworking topics.
First Name: Last Name:
Address:
Optional Extra Address Line:
City: ST: Zip:
Email:
Re-Enter Email Address:
Phone: ( ) -
NO - I do not yet own a MARK 7 or Mark V
YES - I own a MARK 7 or Mark V
Submit
