Spray adhesive
Spray adhesive
When I used spray adhesive on a paper pattern onto a piece of pine wood - when I took the paper off, it left a residue.
What do you guys use as a spray adhesive that might not leave a residue - or - what would you use to remove the residue without affecting the wood?
try denatured alcohol
I used it with success after doing a rocking horse project with The Wood Whisperer. Just don't drink it:D
Forrest
Forrest
Forrest
Huntington Beach, CA
I lightly use a glue stick... after sanding I've never noticed any thing.
I prefer the chepo brand Wexford, from Wallgreen's not Elmers.
Both labels say washable.
Bruce
Ok Ok, I'm up to four now...
'Why' do you think it is 'denatured'.forrestb wrote:I used it with success after doing a rocking horse project with The Wood Whisperer. Just don't drink it:D
Forrest
A tip for the next time you try the spray-on adhesive.... Spray it on your paper, then set it aside or just hold on to it for a minute or two. Let it dry until it's just tacky, like the adhesive strip on a Post-It note. Then stick it to your piece of wood. It will peel off a lot easier and shouldn't leave much residue.
I've had a great deal of success removing paint with Citri-Strip.holsgo wrote:I'm a fan of paint stripper. Will remove anything and I'm referring to the non enviro friendly version. The enviro friendly version couldn't strip a porn star.
Heath
Central Louisiana
Central Louisiana
