phone  (937) 890-5197
Shopsmith Forums
%nbsp;
20 posts 1 2
shopsmith mark VII
#12031 by tsmith624 » Thu Feb 28, 2008 8:49 am
I have an opportunity to buy a mark VII for $300. Haven't seen it yet. What should I be aware of / look for? Since it was not actually made by Shopsmith, is it something to stay away from? I understand the speed control can melt....is it replaceable? Thanks, guys!!
#12033 by Nick » Thu Feb 28, 2008 9:48 am
It was made by Shopsmith in the 50s; but is no longer supported by us. Some of our accessories will work on it, and a few of our repair parts are interchangeable. Bill Mayo can speak to the availability of repair parts from outside the company much better than I can and hopefully he'll jump in here.
The Mark VII was a decent machine, though not the battleship that the Mark V proved to be. If the machine is in good running order and reasonably cheap, it might be prove a fine way to get into woodworking. However, if support, compatibility with available accessories and repair parts, and the ability to be upgraded is important to you, I'd hold out for a used Mark V in your price range.
With all good wishes,
#12041 by mranum » Thu Feb 28, 2008 1:15 pm
Sounds like the one I saw on Craigslist yesterday. Near Appleton WI. ?
If it is the pics looked decent.
buy mark VII ?
#12042 by tsmith624 » Thu Feb 28, 2008 1:24 pm
Yes, it is the same one. As a matter fact, the guy bought it 1 1/2 yr ago after posting some questions on another Shopsmith forum....which I forgot to bookmark.
Shopsmith Mark VII
#12053 by billmayo » Thu Feb 28, 2008 4:56 pm
Thanks Nick for the reference. I did replace a Mark VII headstock with a Mark V headstock. There are several people that own and play with the Mark VII. One is Farmer at robinson46176@yahoo.com who has a collection of them. Another person is at http://www.califsawdustman.com/ who I believe had some Mark VII parts for sale last year. Bob Fulwider (Email = bobrepairs85@sbcglobal Phone after 1000 PST - 775-828-0957 ) had a lot of Mark VII parts for sale last year. I have only done repairs on the Mark V and 10E/10ER Shopsmiths at this time.
Other than the different Speed control setup, it's pretty much the same as a MarkV. Same Quill and drive sleeve (Poly-V), control sheave assembly (only there's the follower out the end instead of the clip), A reversible motor is advertised but both Mark VII I have seen had only an on/off switch. If it has a reversible motor that works, it is worth the $300 for the unique motor capability.
One other major difference is the crank for headstock movement. There's a rack/pinion setup for moving the headstock on the ways. This was removed when using the Mark V headstock.
Bill Mayo
#14596 by osx-addict » Thu Apr 03, 2008 2:14 pm
Just to resurrect this thread a bit.. Someone locally is desperate to get rid of a Mark VII for $150 and it comes with the band saw and extra blades + accessories.. I was tempted to get it to use for parts -- acquiring an extra headstock (albeit perhaps a bit different) and a bandsaw (I've already got one).. Can I use this headstock to make a shorty/mini and can the bandsaw be used on a Mark V?
I realize that I'm missing the proper pieces to make a shorty/mini since the base is significantly different but I should be able to use the tubes and whatnot -- correct? I'd probably scrap the large storage base or remove it from the pedestal if possible for wall-mount storage instead.. Comments?
P.S. I'd probably offer him $100 (or perhaps $75) for the entire shebang if he's desperate as he appears.
Rick
S/W of Los Angeles, CA
1983 Mark V model 510 (SN#140061)
shopsmith mark VII
#14637 by billmayo » Fri Apr 04, 2008 11:31 am
The bandsaw fits the Mark V. You are right, the Mark VII has a separate base which would prevent you from making a MINI or SHORTY from it. If it has the reversable motor that works, I would buy it quickly. Still, $100 would be a good deal. The way tubes are the same diameter as the Mark V. I am sure you can find the pieces needed on Ebay to convert to a Mark V MINI. Good Luck with the purchase.
Bill Mayo
osx-addict wrote:Just to resurrect this thread a bit.. Someone locally is desperate to get rid of a Mark VII for $150 and it comes with the band saw and extra blades + accessories.. I was tempted to get it to use for parts -- acquiring an extra headstock (albeit perhaps a bit different) and a bandsaw (I've already got one).. Can I use this headstock to make a shorty/mini and can the bandsaw be used on a Mark V?
Bill Mayo [url]bill.mayo@verizon.net[/url]
#58323 by nolen » Thu Jan 28, 2010 1:37 pm
I have had a ShopSmith Mark VII since 1966 and used it in all respects. The speed control melted twice, so I had a machinist fabricate one out of aluminum. We also replaced the guides with teflon ones eliminating the posibility of undue friction. This was done in 1997 and "Seven" has performed excellently since. The specs for the speed control are readily available. As for purchasing a Mark V, I highly recommend checking its operation by running through its paces, including attachments, if any. You won't be disappointed if it performs well.
#60563 by schmelifox2 » Sun Feb 21, 2010 8:50 pm
I bought and have been using a mark vii since 99. I just replaced the original forward reverse switch with two switches so can still reverse motor if ever needed. Used a piece of sheet metal behind the old key hole and switch hole to put in dpdt toggle and spdt rocker. Nolen - do you have any spare aluminum speed controls?
#60950 by smithy2010 » Sat Feb 27, 2010 10:02 pm
Have an opportunity to buy a Mark VII. Will the bandsaw work on the Mark V? Can I replace the base with Mark V legs and base?
Who is online
Users browsing this forum: No registered users and 11 guests
Welcome to Shopsmith. Please fill in this form and we'll send you more information about the Shopsmith MARK 7 and other woodworking topics.
First Name: Last Name:
Address:
Optional Extra Address Line:
City: ST: Zip:
Email:
Re-Enter Email Address:
Phone: ( ) -
NO - I do not yet own a MARK 7 or Mark V
YES - I own a MARK 7 or Mark V
Submit
